WiNG access points utilize a built-in Bluetooth chip for specific Bluetooth functional behaviors in a WiNG managed network. Both Bluetooth classic and Bluetooth low energy (BLE) technology are supported. Bluetooth classic-enabled radios sense other Bluetooth-enabled devices and report device data (MAC address, RSSI and device calls) to an ADSP server for intrusion detection. If the device presence varies in an unexpected manner, ADSP can raise an alarm.
WiNG model access points support Bluetooth beaconing to emit either iBeacon or Eddystone-URL beacons. The access point‘s Bluetooth radio periodically sends non-connectable, undirected LE (low-energy) advertisement packets. These advertisement packets are short and sent on Bluetooth advertising channels that conform to already-established iBeacon and Eddystone-URL standards. However, portions of the advertising packet are customizable via the Bluetooth radio interface configuration context.
To switch to this mode, use the following commands in the AP's profile or device context:
<DEVICE>(config)#profile <ap-type> <PROFILE-NAME> <DEVICE>(config-profile-default-ap-type)#interface bluetooth ? <1-1> Bluetooth interface index?
The following example uses the default-ap505 profile instance to configure the Bluetooth radio interface:
nx9500-6C8809(config-profile-default-ap505)#interface bluetooth 1 nx9500-6C8809(config-profile-default-ap505-if-bluetooth1)#? Bluetooth Radio Mode commands: beacon Configure low-energy beacon operation parameters description Configure a description for this bluetooth radio eddystone Configure eddystone beacon payload parameters ibeacon Configure iBeacon beacon payload parameters mode Set the bluetooth opreation mode no Negate a command or set its defaults shutdown Shutdown the selected bluetooth radio interface clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-default-ap505-if-bluetooth1)
| Commands | Description |
| beacon | Configures the Bluetooth radio‘s beacon‘s emitted transmission pattern |
| description | Configures a description for the Bluetooth radio interface |
| eddystone | Configures Eddystone beacon payload parameters. Configure these parameters if the operational mode is set to ‘le-beacon‘ and the beacon transmission pattern is set to ‘eddystone-url1‘ or ‘eddystone-url2‘. |
| ibeacon | Configures iBeacon beacon payload parameters. Configure these parameters if the operational mode is set to ‘le-beacon‘ and the beacon transmission pattern is set to ‘ibeacon‘. |
| mode | Configures the Bluetooth radio‘s mode of operation |
| shutdown | Shutdowns the selected Bluetooth radio interface |
| no (bluetooth-inf-config-command) | Removes or reverts to default this Bluetooth radio interface‘s settings |
